1997 Dodge Stratus Vibration on the Brake Pedal
164,000 MILES • 4 CYL • FWD • AUTOMATIC
LINKINXP
  • 11 POSTS
HI! my cars vibrates when a gear its set , i mean while P or N its ok! but then in D or other speed the Brake pedal vibrates a little bit i wonder why? engine mounting?
thanks in advance
Mar 23, 2008 at 12:05 PM
BMRFIXIT
  • 19,053 POSTS
check tranny and motor mount
check for a tune up
check for vacuum leaks
Mar 23, 2008 at 12:50 PM
LINKINXP
  • 11 POSTS
Will be easy to replace it by myself? do i need to go to a mechanic? and how many does it have ?
Mar 23, 2008 at 1:31 PM
BMRFIXIT
  • 19,053 POSTS
what did you find ?
Mar 24, 2008 at 11:15 AM
LINKINXP
  • 11 POSTS
So let me see how to explain myself the vibration in the brake pedal was the little plastic that goes inside the PCV HOSE! :O yea cause i change it ( THE HOSE) and i forgot to put that little plastic that goes in the engine side of the hose :P and i found it today and BAMB!! its working like a charm today :D i hope this work for future diagnostics thanks for the help will ask again here for sure.
Mar 24, 2008 at 11:52 AM
BMRFIXIT
  • 19,053 POSTS
That was the vacuum leak
good job you found it
happy driving
Mar 24, 2008 at 12:23 PM
LINKINXP
  • 11 POSTS
Thanks ! but!! now i have an error 12 21 55 ( CHECK ENGINE ) and i dont know if its because of that maybe the hose its to FAT , i guess ill have to go to the dealer to purchase the Real one but if u guys know something please let me know thanks....
Mar 26, 2008 at 11:22 PM
BMRFIXIT
  • 19,053 POSTS
P codes will identify the troubled area but I think code 21 is a downstream o2 sensor you may need to check it check fuses and wires
replace o2 sensor
code 12 beginning and 55 ending of codes
good luck
jack
Mar 27, 2008 at 10:11 AM
