1997 Dodge Stratus Transmission Help
1997 DODGE STRATUS
MREICHELDERFER
Transmission problem
1997 Dodge Stratus 4 cyl Front Wheel Drive Automatic
I have a 97 dodge stratus. I recently hit a rock while backing out of a driveway. I hit the rock towards the front of the car. Transmission fluid leaks out when you put the fluid in the car. It leaks on the seam of the transmission to the left (its to the left if you are under the car looking up underneath the car). What could be causing the transmission fluid to leak from the seam? The leak is really bad as it pours out like as if you were turning on a facet.
Oct 14, 2009 at 1:58 PM
  • 110,244 POSTS
Is it leaking between the trans pan and the transmission?
Oct 19, 2009 at 1:43 PM
