1997 Dodge Stratus timing belt
97,000 MILES • 4 CYL • 2WD • AUTOMATIC
KEITHSMITH8
my timing belt broke while the thing was running i'm worried about valve damage should i replace the belt& water pump or put another used engine in there
Jan 24, 2010 at 3:27 AM
BLUELIGHTNIN6
  • 16,542 POSTS
how about replace the belt and see if the valves are bent. if not then problem solved, if so then replace or rebuilt it..
Feb 3, 2010 at 5:45 PM
