1997 Dodge Stratus oil leaking
PATSYLOMAN58
  • 1997 DODGE STRATUS
  • 4 CYL
  • FWD
  • 87,000 MILES
I have changed the oil pan gasket twice and still leaks what am I not doing right
Saturday, February 14th, 2009 AT 7:50 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Are you using proper torque on the bolts?
Tighten the oil pan attaching bolts to 105 inch lbs. (12 Nm).
Although no torque sequence is available, it is recommended that you begin at the center of each side and progress outward, in an alternating pattern.
Thanks for using 2CarPros. Com!
Saturday, February 14th, 2009 AT 7:59 PM
