1997 Dodge Stratus ignition switch
123,000 MILES • 4 CYL • FWD • AUTOMATIC
JOKER79
I have power going into my switch but no power out so i got a knew one and Im still having the same problem what else can it b I used a test light
Jun 15, 2009 at 4:27 PM
CARADIODOC
  • 34,415 POSTS
There are a couple of different circuits going in, and a number of wires going out. Some outputs are hot only in the accessory position, some only in run, some in both, and one only in the crank position. In addition, there is usually one wire that gets grounded in the crank position. That one turns on the red brake warning light as a bulb test.
caradiodoc
Jun 23, 2009 at 6:29 PM
