1997 Dodge Stratus Gages go crazy and then dies
1997 DODGE STRATUS
154,000 MILES • 4 CYL • 2WD • AUTOMATIC
KEK
This started about 6 months ago. While driving the gages will cut out when accelerating then come back when I let off. Then the car started dying suddenly for no reason. When it dies it will not restart for an extended period. I found a burned spot on gage board so replaced gage pod. I still have all gages shutting down and car stalling with car totally dead and no restart
for extended period. If I let it sit over nite it will restart.
Checked wiring but did not find any bad connections or shorts. Any ideas.
Feb 2, 2008 at 8:42 AM
JOHNYPHANTOM
  • 37 POSTS
id try to run a code check on it if posible , it could be the ecm going bad , maybe even a cranshaft sensor
Feb 12, 2008 at 1:44 AM
