1997 Dodge Stratus front end alignment
97,000 MILES • 4 CYL • FWD • AUTOMATIC
EDDYK
Recently I was in a minor fender bender with another car....it dented my passenger front fender and dented the whee (tire did not loose pressure). I had to replace the fender and the wheel...My car now pulls to the left when braking....I talked to an alignment company to get pricing and they said that only the toe was adjustable...the camber and caster were not adjustable. Is this true? If not, how do you adjust the camber and caster?
Oct 15, 2009 at 3:34 PM
BMRFIXIT
  • 19,053 POSTS
CAMBER ADJUSTMENT. Camber is factory preset and cannot be adjusted. If camber is not within specification, replace or repair bent or broken parts as necessary
Oct 15, 2009 at 3:42 PM
