1997 Dodge Stratus engine light on error code 32
176,000 MILES • 4 CYL • 2WD • AUTOMATIC
HAWKER71
need help figuring out what the code is gor my car after cycleing my ignition switch off on 1 am getting codes 12 then 32 then 55 twice i believe code 12 means start of test 55 means end correct me if I am
wrong car running well but engine light on with code 32 please help
thanks hawker you can email me with answer
hawker71 mail .com
Apr 17, 2008 at 10:09 PM
BMRFIXIT
  • 19,053 POSTS
if you can get the P codes will help more
I believe its your EGR system you need to have it checked
codes 32 EGR system and solenoid
Apr 17, 2008 at 11:10 PM
