1997 Dodge Stratus Car shut off while driving
BHEYD07
1997 Dodge Stratus Automatic
While driving to work the other day my car just randomly shut off and my breaks locked up. When I finally came to a stop I tried to turn the car on again and it just made a er er er er noise. So it turned over but wouldn't start. Does anybody have any ideas on what it could be?
Jan 31, 2009 at 8:14 AM
  • 75,988 POSTS
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Jan 31, 2009 at 8:20 AM
