My car had really good air until 2mnts ago when it completely stop blowing cool air out. Now it started to work on and off and just of two weeks ago it doesn't blow out any place but the defrost, even if I have the dial set to the feet or whatever. I took it in and had it looked at and they said it's has to be a short. This makes sense cause around a month ago I turned on my car and it started but I had no radio, no blinkers or anything. I turned my car off and back on again and everything was ok. This has happened a couple of times since then. So my question is could a short be causing my lights and blinkers and air to not work properly? If this is the case will it be expensive and time consuming to fix?
Jun 3, 2008 at 1:55 PM
