We are tring to start the car and the lights come on but the starter will not turn. It is not making any noise.
Nov 3, 2010 at 11:39 PM
JDL
✓Experienced Mechanic
You need to make sure the battery has a full charge. Use a voltage tester across battery posts, everything turned off. The generic spec for a full charge is around 12.6 voltage. Check that all battery connections coming and going are clean and tight on all ends.
