1996 Dodge Stratus Steering wheel shakes
MULDOON
  • 79 POSTS
Shakes or Wobbles problem
1996 Dodge Stratus 4 cyl Two Wheel Drive Automatic 133k miles
Steering wheel shakes, car also shakes when idle in drive stopped at a light, much better in neutral, if it is the mounts how would I know which one of the three, I replaced the dog mount at 60k miles. The a/c on or off does not make any difference, thank you Declan.
Aug 17, 2010 at 11:10 PM
WRENCHTECH
  • 20,760 POSTS
Not sure exactly when your getting that steering wheel shake but if it's while driving, then the first thing you want to do is balance the tires.
As for your vibration when sitting in drive, that would likely be weak motor mounts. Don't try to determine which one. They will all be weak so just change them all.
Aug 17, 2010 at 11:39 PM
MULDOON
  • 79 POSTS
I replaced both top motor mounts and the car is terrific since, not a big job you just cannot give up, thank you Declan.
Sep 3, 2010 at 10:16 AM
WRENCHTECH
  • 20,760 POSTS
Your welcome. Glad you got it resolved.
Feedback is appreciated.
Sep 3, 2010 at 10:36 AM
