1996 Dodge Stratus rough idle
DODGE97INTREPID
  • 1996 DODGE STRATUS
  • 4 CYL
  • FWD
  • 160,000 MILES
96 dodge stratus idles rough will smooth out when you get up to speed but slow down and starts rough again acts like it is loading up.
fuel pressure release valve when depressed with car off has very little fuel come out and with key on it will come out slowly any ideas?
Sunday, March 8th, 2009 AT 11:00 PM
Check the fuel pressure/idle air control valve/throttle position sensor to include the PCV and EGR valves.
Monday, March 9th, 2009 AT 4:16 AM
DODGE97INTREPID
With it not throwing any codes could this still be a problem or could it be something like a fuel pump or filter issue?
Monday, March 9th, 2009 AT 7:09 AM
The only way to tell if its the fuel filter or the fuel pump is to check the fuel pressure. Check the IACV and TPS/MAF sensors.
Monday, March 9th, 2009 AT 7:37 AM
