1996 Dodge Stratus my car is having the same o=problem for
157,000 MILES • 4 CYL • FWD • AUTOMATIC
ALLENPIMP1989
i change the spark plugs, fiul pump fiul filter air filter new oil new oil filter and new casquets the car still doing the same problem the problem is the car fills it wanst to turn off but when it doit at the same time goo back to normal and keep doing it and doing it
Sep 29, 2010 at 11:35 AM
MULDOON
  • 79 POSTS
Did you check the coil pack that may be your problem, it is easy to replace 10mm, 4nuts on top make sure you mark the wires also does engine light come on, Declan.
Oct 3, 2010 at 5:28 PM
