1996 Dodge Stratus I need to know how to change the fuel fi
145,950 MILES • 4 CYL • FWD • AUTOMATIC
KAILI123
I needed to know how to change my fuel filter,and also what all parts and tools I will need?
Oct 13, 2008 at 4:37 AM
ZACKMAN
  • 4,202 POSTS
You need to have the fuel tank almost empty, relieve fuel pressure, detach both cables to your battery (red by the relay box, black on the driver side strut tower), jack the rear of the car and put jack stands.
Put a piece of plywood between your jack and fuel tank (tranny jack works better), loosen the bolts holding the fuel tank straps, lower the tank. Your fuel filter will be on the rear of of the tank, tucked atop the rear frame rail. Loosen the fuel hose clamps, and one bolt holding the filter to the frame. Careful, you will have some fuel spill.
Oct 15, 2008 at 6:48 AM
