1996 Dodge Stratus HOW TO CHANGE BATTERY
98,288 MILES • 4 CYL • 2WD • AUTOMATIC
MONQIEHARD
WHO TO PEPLACE BATTERY
Mar 29, 2009 at 1:43 PM
  • 75,988 POSTS
Remove the battery negative cable 1st then the positive cable for installation connect positive cable then last the negative cable make sure its properly tightened.
Mar 29, 2009 at 1:54 PM
ZACKMAN
  • 4,202 POSTS
Raise front of vehicle.
Removal of front driver side tire not necessary, but will give more room to work with.
Remove wheel well plastic cover.
Remove battery holder bolt.
Follow Rasmataz's direction.
To install, reverse the direction.
Mar 29, 2009 at 6:19 PM
