1996 Dodge Stratus ECM
152,450 MILES • 4 CYL • FWD • AUTOMATIC
JEFFMOLLET
I recently purchaced this car knowing the air conditioning does not blow cold air, The Mechanic said the ECM module is faulty, however he manually wired it together and it worked but will not shut off the compressure. My question is the ECM the problem !!
May 25, 2010 at 12:06 PM
BLUELIGHTNIN6
  • 16,542 POSTS
it's possible, if mechanic diagnosed it as faulty computer and hard wired it to bypass the computer and it works then yes it's most likely the correct diagnosis
May 25, 2010 at 1:30 PM
JEFFMOLLET
Thanks for your reply
May 29, 2010 at 1:15 AM
