1996 Dodge Stratus coolant problem
146,000 MILES • 6 CYL • FWD • AUTOMATIC
DON62
I have coolant buliding up below the air intake. Is there rubber hose that ties to the back of the water pump housing? To a peace of steel tube that goes over to the driver side of the engine. the
steel tube distubes coolant to driver side of heads and ties in to fill neck housing (thermostate housing)
If not would this be a good indication that the water pump is going out?
Sep 12, 2009 at 5:45 AM
  • 110,248 POSTS
Can you take a picture of the problem so I can see what is happening? Also, what size engine is it?
Oct 8, 2009 at 5:04 AM
