1996 Dodge Stratus check engine
FERRODAR
Computer problem
1996 Dodge Stratus 4 cyl Front Wheel Drive Manual
i have a trouble with the 5volt at the iat sensor. i replaced the map sensor which come toghether. still on check engine light and air conditioner doesnt work
what can i do?
Jun 16, 2010 at 12:31 PM
BLACKOP555
  • 10,386 POSTS
get vehicle scanned and post the codes back here in p***** format. from there well figure this out.
Jun 16, 2010 at 3:38 PM
FERRODAR
the code i remember is P0112 is about low voltage at the IAT sensor, the other one i dont remember, it was a bout the 5 volts to the ECM, i checked the map sensor (wich is integrated with the IAT sensor) and there was about 1.05 V at the Map signal and 4.0 at the IAT signal, also checked at the ECM connector and was the same reading.
Also the Air conditioner doesnt work i forced the A/C relay and the engine turned off, and after i checked the codes with the switch key there was code 33 that is about AC failing cluth wiring
Jun 17, 2010 at 9:11 AM
BLACKOP555
  • 10,386 POSTS
id realy like that code about the ecm. it can be causing both codes to show up.
Jun 17, 2010 at 4:56 PM
