1996 Dodge Stratus battery location
CSHOWS
Engine Mechanical problem
1996 Dodge Stratus
do not have owners manual and trying to figure out where the battery is located
May 22, 2010 at 2:21 AM
INTERNETMECHANIC
  • 700 POSTS
I don't have access to an owners manual. You might be able to buy one from Dodge? You access the battery from driver side front wheel-well. You would probably have more room if you remove the driver-side front tire. If you need step by step procedure, let me know, I'll find something.
May 22, 2010 at 3:06 AM
CSHOWS
thank you so very much.
May 22, 2010 at 5:07 AM
JUNKYARDQUEEN
The battery is located in the drivers side fenderwell. Removing the drivers side front tire makes it easier to remove the battery.
Aug 30, 2010 at 4:17 AM
