1996 Dodge Stratus
CMCC59
Engine Cooling problem
1996 Dodge Stratus 6 cyl Front Wheel Drive Automatic
My cooling fans are not coming on properly. I've replaced the coollant temperature sensor, and my relays check good. Is there a possible short some where
Apr 12, 2009 at 2:02 AM
BLACKOP555
  • 10,386 POSTS
the coolant temp sensor is only for the dashboard. the coolant temperature switch is used for the fans. check that one and make sure its working properly.
do fans turn on if hardwired to the battery?
Apr 12, 2009 at 2:08 PM
