1995 Dodge Stratus spark plug location: can't find them
160,000 MILES • 6 CYL • FWD • AUTOMATIC
HARDENEDELEMENT
I need to spray some silicone on the spark plug wires because i had been told that moisture is settling overnight on them causing my engine to not turn over. If i could only find them....eventually i will replce them.
Jan 9, 2008 at 3:51 AM
BLACKOP555
  • 10,386 POSTS
first find the spark plug wires that would be the best way to find them if you dont see no visible spark plug wires , then you may want to take off the plastic cover on top of the engine and they will be located under that.
Jan 9, 2008 at 11:33 AM
