1995 Dodge Stratus Oil Leaking from Valve Cover
BUDDHALUV79
  • 42 POSTS
Engine Mechanical problem
1995 Dodge Stratus 4 cyl Automatic
I have a 1995 Dodge Stratus, 4 cylinder, 2.4 engine...2 of my valve cover bolt holes seemed to be stripped and the bolts won't tighten so oil is coming out of the bolt holes. What can I use or do to get the bolts to tighten down?
Sep 20, 2010 at 5:42 AM
BLUELIGHTNIN6
  • 16,542 POSTS
expensive way is getting a new cylinder head, or you could try re tapping the 2 holes and using new slightly larger bolts there.
Sep 20, 2010 at 8:22 AM
MULDOON
  • 79 POSTS
Put lots plumbers tape on the treads on the bolts but do not over tighten it will work, Declan.
Oct 3, 2010 at 5:32 PM
