1995 Dodge Stratus front driver seat
417,123 MILES • 6 CYL • FWD • AUTOMATIC
ITSSHREK42
someone from the back seat had pulled hard enough to break something on the pivot side of the seat. it's where the pivot bolt meets the bottom pan. i need to know how the seat back is joint to the bottom even though the pivot bolt is still intact. is there a bracket that is welded or something to the bottom pan? if you have a diagram of both top and bottom metal components and how they are joined it would be very helpful
May 30, 2008 at 8:58 PM
MERLIN2021
  • 17,250 POSTS
Your best bet is a used seat from a junkyard...you would need to remove the seat from the car, remove the upolstery, and weld the broken metel...
May 30, 2008 at 9:07 PM
