1995 Dodge Stratus
JC95
Engine Performance problem
1995 Dodge Stratus 4 cyl Two Wheel Drive Automatic
car runs great but, car bucks for a second while giving gas,,,this bucking happens frequently. I was told from non professional today who drove with me it could be a throttle protector or vapor sensor??
Jul 14, 2010 at 11:56 AM
  • 75,988 POSTS
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 14, 2010 at 3:17 PM
