1995 Dodge Stealth not getting any real heat from heater co
84,000 MILES • 6 CYL • FWD • AUTOMATIC
MIKEVALVE1
just got the car and the dealer flushed the heater core. the temperture of the air improved a little. I drove for over an hour and the gage was almost up to halfway when just like that it went almost down to "c". I dont have repair history for this car. Should I replace the thermostat and coolant temperture sensor? Is there there something else.
Dec 17, 2007 at 7:10 AM
MERLIN2021
  • 17,250 POSTS
I would at least check the thermostat. If you do replace it, point the spring to the block. After that, Try warming the Vehicle, then carefully feel the heater hoses, are they both hot? If one is cooler than the other, you may need s replacement job on the heater core. Also if the system has a heat control valve on the heater hose, make sure it is working!
Dec 17, 2007 at 7:14 AM
