1995 Dodge Stealth Door locking problem
110,000 MILES • 6 CYL • FWD • MANUAL
RBLUE22
The doors (driver's and passenger) can be locked and unlocked by key.
My drivers side door switch will not lock the driver's and passenger side doors, but it can unlock both.
The passenger side switch can lock and unlock both the driver's and passenger side (no problem there).
I did replace the driver's side switch (new), but I am having the same problem.
Jan 4, 2009 at 10:51 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
It sounds like there may be a short in the wiring to the driver's switch. Test and inspect the wires going to the switch. See if there are any loose connections at both ends of the wiring and also test the wires with meter to track down any shorts/open circuits.
Hope this helps..
Thanks for using 2carpros.com!
Jan 4, 2009 at 11:43 AM
