1994 Dodge Stealth Starting problems
50,000 MILES • 6 CYL • FWD • AUTOMATIC
JAA6921
I have had my 94 Dodge from new and its pristine with low miles. The problem I have is that when I try to start it, I turn the key and the starter motor does not immediately turn - its as if the electronics delays the start - and sometimes I have to return the key to off and try again. HAs anyone else experienced this tup of problem - I sure would like to make starting a more positive process.
Any suggestions on what may have changed that I can fix - like loose connections etc??
Thanks
John A
Dallas TX
Dec 22, 2009 at 9:07 AM
  • 75,988 POSTS
Your problem could be one of the following: Starter ,starter relay, park/neutral position switch and ignition switch-Double check battery condition and connections.
Dec 22, 2009 at 9:24 AM
