1994 Dodge Stealth Brake Issues
105,800 MILES • 6 CYL • FWD • AUTOMATIC
IKE016
I have bled my brakes, changed out the pads, master cylinder and can find no visisble signs of a leak. My issue is that my brake pedal goes to the floor and I have to refill my fluid about once a week. When I do bleed the brakes they work for a few days and then it is back to the same old pedal to the floor.
Mar 9, 2009 at 7:25 PM
DOCFIXIT
  • 18,828 POSTS
Rears are good? if so unbolt master from booster pull it away a little see brake fluid? if yes master is leaking into booster
Mar 10, 2009 at 5:54 AM
