1993 Dodge Stealth Won't crank..
1993 DODGE STEALTH
WUKI88
Engine Mechanical problem
1993 Dodge Stealth 6 cyl Front Wheel Drive Automatic 159XXX miles
My car is a 93 stealth this car started fine but the one day wouldn't even crank. about a week later I was able to start the car but once I turned it off it would not even try to turn over! Could this be the starter or the ECM I don't have alot of money and I am hoping it's just the starter! [img:15dc6dccbf]http://www.2carpros.com/forum/automotive_pictures/500096_IMAGE_163_1.jpg[/img:15dc6dccbf]So could the ECM cause the car not to even try to turn over or is that all on the starter?
Mar 13, 2010 at 3:47 PM
No crank at all/nothing/nada:
Could be the starter, starter relay, park and neutral switch/clutch switch and ignition switch assuming the battery and connections are good.
Mar 13, 2010 at 4:55 PM
