1993 Dodge Stealth Throttle idling problem
MILAN99224201
Engine Mechanical problem
1993 Dodge Stealth 6 cyl Manual 130000 miles
ok from time to time when my car is idling the rpms will bounce up and down from 1500 to 2000 rpms and then eventually just maintain at 2000 rpms like the engine is reving. i had this problem a few times and had it fixed in ny state but i live in ny now and i called my father to ask him what it was and he said it was the throttle air control valve and i need to spray some carb cleaner on it but i dont know how to locate that part or if thats even the problem can anyone help me?!?!
Apr 15, 2010 at 6:43 AM
  • 75,988 POSTS
Check and test the idle speed control servo on the throttle body assembly and also the idle switch built into the throttle positon sensor
Apr 15, 2010 at 10:39 AM
