1993 Dodge Stealth No 5th gear
150,000 MILES • 6 CYL • FWD • MANUAL
BRIGHTBLADE1
When driving or setting still you can shift to 5th gear and its like its not there. No grind, no noise what so ever. Every other gear works fine, including reverse. It doesn't feel like its even connecting or locking into place. Well i'm at loss ??
Feb 19, 2008 at 10:24 AM
GAGEONINJA
try checking the trans oil for how warn the fluid is and or if it needs to be changed. next i would check your shift linkage and fluid at the clutch resivior. it sound like a linkages broke so your shift fork cant engage the tranaxles drive line into 5th gear.
Jun 22, 2008 at 10:50 PM
