1993 Dodge Stealth Engine Stalls
DAKOTA_DAVE83
Engine Performance problem
1993 Dodge Stealth 6 cyl Two Wheel Drive Automatic
Engine starts and ildes normally. Back out of driveway, place in "Drive", engine tries to (or does) stall. When stopping for stop sign or red light, if left in "Drive", engine rpms drop, then engine stalls. Does not do this when transmission is in "Neutral". Engines runs normally in other driving conditions. "Check Engine" light is not on. Oil pressure, charging amps, engine temp all normal.
Dec 30, 2009 at 12:11 PM
  • 75,988 POSTS
Clean out the Idle Air Control Motor and EGR Valve and Throttle Position Sensor.
Dec 30, 2009 at 12:52 PM
