1993 Dodge Stealth Car Wont Start
200,000 MILES • 6 CYL • FWD • AUTOMATIC
CARLESMITH32
I have replaced the fuel pump on this vehicle, but it still will not start. The engine sounds like it is turning, but it just wont start. What else can I check or replace myself before is should consider taking it to the shop. If you think it is the timing belt I will have to take it to the shop I dont have the means to fix that problem at home.
thanks
Oct 6, 2010 at 3:49 AM
  • 75,988 POSTS
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
Oct 6, 2010 at 5:36 AM
