1993 Dodge Stealth
86,000 MILES • 6 CYL • FWD • AUTOMATIC
KEVINVERBAL
how do i test the throttle position sensor on this car
Mar 25, 2010 at 9:48 PM
  • 75,988 POSTS
Throttle Position Sensor
https://images.2carpros.com/forum/automotive_pictures/12900_ts_3.gif
1.Disconnect the Throttle Position Sensor connector. Throttle Position Sensor Test Connection
https://images.2carpros.com/forum/automotive_pictures/12900_ts1_2.gif
2.Measure the resistance between terminal # 1 and terminal # 4 of the TPS. Refer to SPECIFICATIONS/ELECTRICAL . Throttle Position Sensor Test Connection
https://images.2carpros.com/forum/automotive_pictures/12900_ts2_1.gif
3.Connect a pointer-type ohmmeter between terminal # 2 and terminal # 4. 4.Check the resistance while slowly opening the throttle valve from the idle position to the full open position. Resistance should change smoothly in proportion with the throttle valve opening. If there is a deviation from the test results, replace the TPS. Refer to COMPONENT REPLACEMENT AND REPAIR PROCEDURES. https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Mar 25, 2010 at 11:37 PM
