1993 Dodge Stealth
17,700 MILES • 6 CYL • FWD • MANUAL
MR.KRINKLE
  • 5 POSTS
I just bought a 93 Dodge Stealth ES and if it sits for a few minutes after running the exhaust begins to emit smoke and then if you give it some gas it eventually clears itself out of smoke. It seems to run fine and maintains a stable pressure and temperature. It does not leak at all. However, I know this is not the inteneded design of the cars performance and I would like to know steps I can take to prohibit this from getting any worse. I am sure that with it having 177,000 miles on it the engine is not tip top but seems to be holding up and before running out and buying a new engine I would like to salvage/prolong the engine in it now. Would "steel seal" be of any help seeing as how it is most likely bad rings? Thanks for your input and help. Also, when it comes time to get a new/rebuild engine, is it possible to put the turbo engine in this thing?
Sep 9, 2009 at 8:07 AM
DOCFIXIT
  • 18,828 POSTS
Most likely valve stem seals and worn valve guides. Does it smoke if you bring RPMS up high then let off throttle quickly?
Sep 9, 2009 at 8:23 AM
MR.KRINKLE
  • 5 POSTS
Not that I have noticed yet. How much does repair on somthing like that run you think?
Sep 10, 2009 at 10:19 AM
DOCFIXIT
  • 18,828 POSTS
Steam seals if don't pull heads @$600-$800 if guides are needed @$1400-$1800
Sep 11, 2009 at 8:27 AM
MR.KRINKLE
  • 5 POSTS
At that price I will prob just buy a rebuil when it happens. Thanks my friend!
Sep 14, 2009 at 3:03 PM
DOCFIXIT
  • 18,828 POSTS
Probably best option
Sep 15, 2009 at 6:55 AM
MR.KRINKLE
  • 5 POSTS
What about putting a tt engine in it? It is the es 222hp 3.0l and the tt is 3.3l 300hp dual exhuast. Would it be a very difficult task or is it even possible?
Sep 15, 2009 at 10:37 AM
DOCFIXIT
  • 18,828 POSTS
Not sure I'll check around
Sep 17, 2009 at 1:16 AM
MR.KRINKLE
  • 5 POSTS
Thanks
Sep 17, 2009 at 10:04 AM
