1993 Dodge Stealth
BIAGIO_X
Transmission problem
1993 Dodge Stealth Front Wheel Drive Automatic 110000 miles
after driving for approx.30 minutes loses overdrive & 2nd gear.Also lose them when turning on a off ramp.Transmission was rebuilt then the car was parked for approx. 2 years.Oil was changed when i got the car & modifier was added.(after problem discovered).may this problem be in valve body???.when prolblem occurs,I manually shift transmiission & seems ok(down shifting & up shifting).Any thoughts & advice would be great.
Jul 23, 2008 at 4:00 PM
  • 31,937 POSTS
Hi there,
You may have a sticky valve in the valve body, this is not uncommon when cars are stored for a period of time, i would drive it for a while to see if it frees up, otherwise it will be a trip to a trans shop for further investigation.
Mark (mhpautos)
Jul 23, 2008 at 5:50 PM
