1992 Dodge Stealth valve cover gasket
SWEETGEORGIAGIRL
Engine Mechanical problem
1992 Dodge Stealth 6 cyl Front Wheel Drive Automatic
What's the easiest way to remove and replace the rear valve cover gasket on the 3.0 SOHC engine ?
May 28, 2010 at 6:43 AM
DAVID HUNT
The easy way to repair this gasket , is to remove to top half of the aluminum spider or AIR INTAKE Plenum. Discconnect all cables, vacume lines, and remove plenum. Besure to have new intake gaskets when reverse put together. This opens engine access to valve cover,.....or you can pull out the engine to work on that valve cover. Have a great day, hope this helps. Inspector Mopar
Jun 23, 2010 at 9:26 AM
