1992 Dodge Stealth OIL LEAK and clunking as i let off gas p
1992 DODGE STEALTH
163,000 MILES • 6 CYL • 2WD • MANUAL
IAMGAMEVIXEN
If my stealth has an engine mount that needs replaced would that be a cause of a sudden oil leak or is the leak from the oil pressure switch and how do I find a diagram of the engine please not somewhere that costs an arm and leg
Oct 6, 2009 at 1:12 AM
CH112063
  • 1,320 POSTS
Why not try the owners manual section that is available here. If you do it yourself it will pay for itself and you can have a source of valuable information.
If not secured properly alot of damage may occur and the oil switch may not be the only leak. I hope it is for your sake. ok Joe
Oct 7, 2009 at 12:43 PM
