1992 Dodge Stealth Bleeding Procedure?
180,000 MILES • 6 CYL • AWD • MANUAL
MARHONG
  • 22 POSTS
Hey guys, I have an all wheel drive dodge stealth with ABS. I need to replace one of the brake lines that runs from the Master cylinder to the ABS modulator, I just wanted to know how i should go about it? Just staright replace? Drain the master cylinder first? Because it is also being removed from the ABS module, is there a special bleeding procedure for that too? Thanks.
Oct 17, 2009 at 11:24 AM
BMRFIXIT
  • 19,053 POSTS
ths is what i have on the subject
BLEEDING PROCEDURES
Bleed brakes whenever hydraulic lines are opened or pedal feels spongy. Bleed hydraulic system in appropriate sequence. Refer to the BRAKE LINE BLEEDING SEQUENCE table. On all models except Montero, Pickup and Ram-50, bleed system with engine running
BLEEDING SEQUENCE table:
Diamante, Eclipse, Galant, Stealth & 3000GT
RR, LF, LR, RF
Oct 17, 2009 at 11:45 AM
