1991 Dodge Stealth no spark
150,000 MILES • 6 CYL • FWD • MANUAL
KROM
when i turn on my car this mornig it started to shake like if it was lossing power, so what i did was that i check the wires to see if they were loose but everything seem ok. Then i remove one of the wires from the coil-ignition with the car runnig to check for a spark and it had spark and then i check the others and from one of the coils there is no spark at all. i replace that coil-ignition and there is still no spark whats up with that, what can the problem be??
Aug 28, 2008 at 12:38 PM
BLACKOP555
  • 10,386 POSTS
check to see if it is getitng +12v constant with key on, if it is then there is something bad with the ground trigger, trace teh wire back.
Aug 28, 2008 at 2:35 PM
