1991 Dodge Stealth Degreased the engine
GQCWBY
Noises problem
1991 Dodge Stealth 6 cyl Front Wheel Drive Manual
I have recently degreased the engine and now i am hearing the alternator whine. I know its not the belts or the pulleys.
Will this go away eventually. It was quiet before the engine was cleaned
Oct 25, 2008 at 5:24 AM
DOCFIXIT
  • 18,828 POSTS
Not supposed to get degreaser or water in alt. You probably got rectrifer bridge wet and your hearing a diode whine. May dryout in time. Check alt output if good and no weird running problems turn up your good.
Nov 3, 2008 at 7:26 AM
