2005 Dodge Srt-4 Clutch or Clutch master cylider malfuntio
2005 DODGE SRT-4
37,500 MILES • 4 CYL • FWD • MANUAL
REVERANDMANSON
For the past week I've been able to shift up through the gears without a problem, but when downshifting it has been nearly impossible to get into 2nd or 1st gears. Now, however, it will only ocasionally go into gear. When it does it's usualy with a thunk. It will start while in gear but will not come out of gear. I hear no grinding, however, the clutch pedal vibrates under foot. In order to get he car home I had to turn it off at any redlight in order to put it into gear. Sometimes though it alowed me to shift while still moveing but only with more than average pressure.
May 1, 2009 at 9:40 AM
Check the clutch master cylinder and slave if okay try adjusting for free play and height that don't make it time to investigate the clutch assy.
May 1, 2009 at 9:47 AM
