2007 Dodge Sprinter replacing disc brake pads
2007 DODGE SPRINTER
GGEBHART
Brakes problem
2007 Dodge Sprinter Two Wheel Drive Automatic 50,000 miles
My engine is a 3.0 liter 5 cylinder diesel (no option above).....can't figure out how to release "bolt" on the front caliper. Have not even checked the rear.
Specifically: what tool is required to release guide bolts?
Apr 15, 2010 at 8:17 AM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
which bolt you trying to remove? the wear indicator bolt (2) and guide bolt (3) are only ones need to be removed for brake pad replacement.
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_12.png
Apr 15, 2010 at 9:55 PM
