2006 Dodge Sprinter Trans locked in 2nd gear.
2006 DODGE SPRINTER
RFSTH
Transmission problem
2006 Dodge Sprinter Two Wheel Drive Automatic 90000 miles
Code po 715 input turbine speeds sensor circuit non functional control. How, where,and location and difficulity to replace by a novice owner mechanic?
May 16, 2009 at 3:10 PM
MIKE H R
  • 3,094 POSTS
I looked up the turbine speed sensor circuit, The circuit is hard wired into the transmission and looking up where it is it came back as being under the drivers seat
https://images.2carpros.com/forum/automotive_pictures/54223_Graphic_3.jpg
May 17, 2009 at 3:39 AM
PEDROFARIA
  • 11 POSTS
i have the same issue on my 06 dodge sprinter and my mechanic is guesing the electronic plate on the valve body. but i'm not sure and the plate is a cost of $500. if anybody can help me i really apreceate.
Oct 26, 2010 at 12:14 AM
MIKE H R
  • 3,094 POSTS
Different garages get things from different suppliers, check around to so you can find the average price of the throttle body, you could also check with a couple salvage yards around to see what they charge for one.
Oct 26, 2010 at 2:48 AM
