2006 Dodge Sprinter please help
126,000 MILES • 6 CYL • 2WD • AUTOMATIC
SPRINTERLUVER
just replaced turbo resonator, engine light turned off and then came back on. shut it off and then start again will rev over 4000 rpms and decreases to 2900 after a min. replaced air filter and fuel filter. brought it to auto zone code po201 came up something with cyclinder 1, what next??
Feb 11, 2010 at 7:08 AM
DOCFIXIT
  • 18,828 POSTS
Was code possibly P2011? if yes then fault with Mass Air Flow sensor. Any leaks in air plenum?
Feb 11, 2010 at 7:29 AM
SPRINTERLUVER
[quote:643529a887="Docfixit"]Was code possibly P2011? if yes then fault with Mass Air Flow sensor. Any leaks in air plenum?[/quote:643529a887] no im pretty postive it is po201 made sure i wrote it down
Feb 11, 2010 at 8:13 AM
DOCFIXIT
  • 18,828 POSTS
Code means fault injector # 1 possible short to ground. Ohm check injector driver coil for open. Then to ground ie.cylinder head. If coil open or reads to ground replace
Feb 12, 2010 at 4:05 AM
SPRINTERLUVER
[quote:e94877434b="Docfixit"]Code means fault injector # 1 possible short to ground. Ohm check injector driver coil for open. Then to ground ie.cylinder head. If coil open or reads to ground replace[/quote:e94877434b] im sorry i didnt reply to your answer, but your info was useful and helped me, but now i have other problems... was sure if anyone read my new question, i just want fix my sprinter and sell it. i love it but i cant afford the repairs, seems like its alwaqys something else. please help me!!!!
Mar 20, 2010 at 6:48 AM
