2005 Dodge Sprinter Blower motor blowing weak
112,000 MILES • 4 CYL • 2WD • AUTOMATIC
MATT ANDREASEN
Its a five cylinder by the way not four. The heater air conditioning blower motor blows weaker than normal on all four speeds. If I remove the insulation under the hood exposing the blower motor and plug into the blower. If I wiggle the plug it operates at full normal speeds for a while then returns to weaker blowing power on all four speeds. Is it the plug and or blower motor or other.
Dec 5, 2009 at 9:58 AM
  • 75,988 POSTS
If you wiggle the wire and goes full speed ahead check the wiring and also the blower motor resistor and the ground circuit.
Dec 5, 2009 at 10:31 AM
MATT ANDREASEN
how do you do that?
Dec 5, 2009 at 12:30 PM
