oxygen sensor problems
DIRTMOD454
I have a 1990 dodge spirit with the 2.5L 4 cyl. non-turbo. It has 162,000 kmi. Recently I have put 3 oxygen sensors in it in the last 1 1/2 years. They seem to fail about every 5000 miles or so. What could be causing this????
Feb 7, 2007 at 2:23 AM
  • 75,988 POSTS
Could be contaminated with coolant or oil sending an inorrect info to the computeril
Feb 7, 2007 at 8:58 AM
DIRTMOD454
I made sure the sensor connections were clean of dirt and oil. They fail regardless. I have even taken the time periodically to spray the connections with contact cleaner to prevent contamination. Sensors still don't last very long.
Feb 7, 2007 at 12:53 PM
  • 75,988 POSTS
Am talking about the internal part of the O2 sensors not external
Feb 7, 2007 at 2:57 PM
DIRTMOD454
That is possible, However the car hardly burns any oil and coolant level remains normal. I really am baffled as to what the cause is. The check engine light never comes on when they go bad either.
Feb 8, 2007 at 12:52 AM
  • 75,988 POSTS
[quote:d8b6fbea97="dirtmod454"]That is possible, However the car hardly burns any oil and coolant level remains normal. I really am baffled as to what the cause is. The check engine light never comes on when they go bad either.[/quote:d8b6fbea97]
Is it OEM O2 sensors
Feb 8, 2007 at 6:42 AM
  • 75,988 POSTS
Check for fault codes and wiring to the 02s
Feb 8, 2007 at 8:08 AM
