Noisey Fan Belt
TREYM111
  • 7 POSTS
hi-
i drive a dodge spirit. every time i start the car the fan belt squeals! if i press on the gas the sound gets louder! i have to wait for it to stop squealing before i put it in gear and go.
also, when i run the heater it squeals until i turn the heater off.
do i need a new belt? can i use a spray like Belt Dressing to make it stop?
thanks!
Nov 3, 2007 at 6:28 AM
MERLIN2021
  • 17,250 POSTS
Generally speaking, if the belt makes noise, it's for 2 reasons, either it's old and fraying, or it's loose, if it's one belt, called a sepentine, you need to change it and the tensioner...
Nov 3, 2007 at 6:46 AM
TREYM111
  • 7 POSTS
there are two belts. the skinnier one is fraying a little and the wider one is fine.
Nov 3, 2007 at 8:55 AM
