At and idle the pressure is low & as you speed up the pressure gets higher
Tuesday, October 14th, 2008 AT 1:04 PM
MECHANIC
Hi:
It's normal for it to increase when the RPMs are increased and decrease at an idle. However, it needs to maintain a minimum pressure. How low does it get? If there is an indicator on the gauge that tells when it's too low are you in that range?
